I’m using the latest version of Grafana on WIndows 10 Pro
Dashboard Functionality
By collecting metrics from Prometheus -
What happened?
only some information is populating on the dashboard
For the dashboard to work
Here is my generator.yml config\
auths:
public_v1:
version: 1
public_v2:
version: 2
modules:
Default IF-MIB interfaces table with ifIndex.
if_mib:
walk: [sysUpTime, 1.3.6.1.2.1.2.2, 1.3.6.1.2.1.31.1.1]
lookups:
- source_indexes: [ifIndex]
lookup: ifAlias
# Uis OID to avoid conflict with PaloAlto PAN-COMMON-MIB.
lookup: 1.3.6.1.2.1.2.2.1.2 # ifDescr
# Use OID to avoid conflict with Netscaler NS-ROOT-MIB.
lookup: 1.3.6.1.2.1.31.1.1.1.1 # ifName
overrides:
ifAlias:
ignore: true # Lookup metric
ifDescr:
ifName:
ifType:
type: EnumAsInfo
Default IP-MIB with ipv4InterfaceTable for example.
ip_mib:
walk: [ipv4InterfaceTable]
readynas:
walk:
- 1.3.6.1.4.1.4526 # Raid/Disks status
Synology
Synology MIBs can be found here:
http://www.synology.com/support/snmp_mib.php
http://dedl.synology.com/download/Document/MIBGuide/Synology_MIB_File.zip
Tested on RS2414rp+ NAS
synology:
walk:
- 1.3.6.1.4.1.6574.1 # synoSystem
- 1.3.6.1.4.1.6574.2 # synoDisk
- 1.3.6.1.4.1.6574.3 # synoRaid
- 1.3.6.1.4.1.6574.4 # synoUPS
- 1.3.6.1.4.1.6574.5 # synologyDiskSMART
- 1.3.6.1.4.1.6574.6 # synologyService
- 1.3.6.1.4.1.6574.101 # storageIO
- 1.3.6.1.4.1.6574.102 # spaceIO
- 1.3.6.1.4.1.6574.104 # synologyiSCSILUN
- 1.3.6.1.4.1.6574.3.1 # raid table
lookups:
- source_indexes: [spaceIOIndex]
lookup: spaceIODevice
drop_source_indexes: true
- source_indexes: [storageIOIndex]
lookup: storageIODevice
- source_indexes: [serviceInfoIndex]
lookup: serviceName
- source_indexes: [diskIndex]
lookup: diskID
- source_indexes: [raidIndex]
lookup: raidName
overrides:
diskModel:
type: DisplayString
diskSMARTAttrName:
type: DisplayString
diskSMARTAttrStatus:
type: DisplayString
diskSMARTInfoDevName:
type: DisplayString
diskType:
type: DisplayString
modelName:
type: DisplayString
raidFreeSize:
type: gauge
raidName:
type: DisplayString
raidTotalSize:
type: gauge
serialNumber:
type: DisplayString
serviceName:
type: DisplayString
version:
type: DisplayString
UCD-SNMP-MIB
University of California, Davis extensions. Commonly used for host
metrics. For example, Linux-based systems, DD-WRT, Synology,
Mikrotik, Kemp LoadMaster, etc.
http://www.net-snmp.org/docs/mibs/UCD-SNMP-MIB.txt
ucd_la_table:
walk:
- 1.3.6.1.4.1.2021.10.1.2 # laNames
- 1.3.6.1.4.1.2021.10.1.5 # laLoadInt
- 1.3.6.1.4.1.2021.10.1.6 # laLoadFloat
lookups:
- source_indexes: [laIndex]
lookup: laNames
ucd_memory:
walk:
- 1.3.6.1.4.1.2021.4 # memory
ucd_system_stats:
walk:
- 1.3.6.1.4.1.2021.11 # systemStats
no errors just no data in certain panels
yes. I am recieving metrics on the prometheus interface and am able to query results for the NAS
