I have iobroker, influxdb2 and grafana in the latest version.
What options are there to switch a light on and off from Grafana in ioBroker (Zigbee), for example?
Can you leverage GitHub - ioBroker/ioBroker.node-red: Instantiate the server with node-red or is there an javascript module that you can use?
for the latter it should be possible using business text
If Business Texts is a plugin, I can’t find it.
I have installed the Business Text plugin.
But it is very complicated to use.
I need to look for instructions, especially an example.
It is possible that it can be done with Business Forms. But that is just as difficult and it is questionable whether I will get the solution that way.
the official documentation should help
it looks like there is no solution for my actual problem. I would have had a hard time imagining that I could change a value in ioBroker from Grafana.
