Very customized panel
HI! I looking for a plugin to make a dashboard like this, with many personalize options. Recently i use flowcharting but it doesn’t allow me to make beautiful gradients (i dont talking about gradients between thresholds)
have you checked out the canvas plugin?
Yes, but canvas doesn’t allow me to make custom gradients depending on the value, or even change the text color to white for example
Have you tried building something like this:
it’s not as pretty but you can style it with css
I’m looking for something that has customization with a single panel, I found a plugin called “FlowCharting”, im testing now.
You may use a SVG panel and use SVG transforms and animations. Also you may use mqtt data source to have realtime updates.
