And its working as expected. I was able to work with it perfectly !
But suddenly, I can see sign in button in the left side on the screen still visible, after successful login with admin credential.
Although, I can see my dashboards, still i can’t see settings and other options.
Attached is an image for reference.
Yes when i login successfully, using admin credentials, i can see the sign-in button still showing, I have tried using google chrome, Firefox. Yes, its showing in every login.
I upgraded Grafana to Ver 7.3.1 in my local system from older version (Windows 10) to test if the same version is working or not !
And its working fine in my local system (Windows OS) using admin credential, able to see all options , and sign-out option.
But I can see this issue, in Linux server (NAME=“Red Hat Enterprise Linux” VERSION=“8.2 (Ootpa)” ) with same grafana version.
In grafana.ini file, org_role was changed to “Viewer” permission.
Thats could be a reason why, using Admin login, I was able to view dashboards only. And Other options/permission were not visible.
Setting with org_role = Admin, in grafana.ini file, resolved the issue.
# specify role for unauthenticated users
**org_role = Admin**
But now I am not able to reset my password while login. (If I needed) .
Also, sign-out option I can’t see !
Still I can see Sign-In option, left side below in the screen.
Please see my screenshot, I have highlighted.
This is very important for me, can some-one please help me to resolve these issues.
this is now a new problem, could you make a new topic because people that know the answer would not come because of the topic that is telling something different
