Hi everyone,
I’m experiencing a repeatable crash when running Grafana on my Rock Pi 4 (ARM64), starting from Grafana v11.6.x and continuing into v12.x.
The error is a SIGILL: illegal instruction that happens immediately when starting grafana-server (even with -v).
My setup
- Board: Rock Pi 4B
- CPU: Rockchip RK3399 (ARM Cortex-A72 x2 + Cortex-A53 x4, ARMv8-A 64-bit)
- Architecture: ARM64 (aarch64)
- RAM: 4 GB
- OS: Debian GNU/Linux 10 (Buster) minimal, kernel 4.4.154-rk3399
- systemd: 241
- Installed via
.debpackage from Grafana’s official download site (arm64builds, notamd64)
Steps I performed and versions tested
- Installed v12.1.0 (
grafana_12.1.0_arm64.deb)
- Service fails to start.
systemctl statusshows multiple warnings like:
Unknown lvalue 'ProtectClock' in section 'Service', ignoring
- Running
/usr/sbin/grafana-server -vcrashes immediately with:
PC=0xac26050 m=0 sigcode=1
Stack trace points to github.com/tetratelabs/wazero/internal/platform/cpuid_arm64.
2. Tested v11.6.4 (grafana_11.6.4_arm64.deb)
- Exact same
SIGILLcrash as v12.x.
- Installed v11.0.6+security~01 (
grafana_11.0.6+security~01_arm64.deb)
- Works perfectly. Service starts normally, no crash.
- Prevented upgrades
- Since
apt-get upgradetries to replace it with v12.x, I ran:
sudo apt-mark hold grafana
- Now the package stays pinned to v11.0.6 and runs without issues.
Crash output example
Here’s the start of the crash log when running any version >=11.6.x:
instruction bytes: 0x0 0x6 0x38 0xd5 ...
github.com/tetratelabs/wazero/internal/platform.getisar0()
github.com/tetratelabs/wazero@v1.8.2/internal/platform/cpuid_arm64.s:11
Hypothesis
It seems that recent Grafana versions include Wazero (a WebAssembly runtime in Go) which uses certain ARM64 CPU instructions.
My Rockchip RK3399 CPU might not support some of these instructions, causing SIGILL.
This would explain why older v11.0.6 works but 11.6.x and 12.x crash immediately.
Question
- Is this a known compatibility issue with certain ARM64 CPUs (like RK3399)?
- Is there a way to build Grafana >=11.6.x for ARM64 without the incompatible Wazero instructions?
- Should I expect a fix, or should I stick to v11.0.6 for this hardware?
Thanks in advance for any help or confirmation!
