I try to create bar chart. Value is shown, but no chart. If remove r[“build_result”] == “SUCCESS”) the chart is shown, but now it shows also failed results.
welcome to the
forum, @samim
if so, can you please follow these steps to share your raw unformatted data? That way, the community can try and mock up your problem ![]()
