Grafana query interval
Hi ,
I am using grafana 10.3.3
I have a single panel where I am showing multi-frame time-series data.
The moment I change my drop -down selection, the query ( REST call to the back end ) gets triggered and update the panel.
My requirement is to delay this query triggering by 2 mins.
Is there any configuration parameter available to grafana to control this ?
How to achieve this?
Any pointers?
Thanks,
Nilanjan
which plugin are you using to make the rest api call?
Hi ,
I am using Infinity plugin …
Thanks,
Nilanjan
There is no delay functionality in that plugin
Maybe you can use JavaScript to do the delay with this plugin
