Grafana 8.0.3
Influxdb 2.0.6
Linux Server -
Getting Data displayed from Influxdb
I try to get Data shown in Influxdb 2.0.6 displayed in grafana 8.0.3
Solved the Flux Version!
I also tried to follow this guide Use Grafana with InfluxDB OSS | InfluxDB OSS 2.0 Documentation
Which means I made a v1 Database that links to my v2 Bucket ID
influx v1 dbrp list
ID Database Bucket ID Retention Policy Default Organization ID
07bdde95ccffe000 initial 9fd40fbfcd4001b5 initital-rp true 1***d
and use InfluxQL
http://****:8086
Access Server
Custom HTTP Headers
Header: Authorization
Value: Token ****
Database initial
User top
Password ****
HTTP Method GET
“Data source is working”
Now running InflusQL I can open the Query Explore, but when I click on the dropbox for “select measurement” it is empty.
GET http://####/api/datasources/proxy/1/query?db=initial&q=SHOW MEASUREMENTS LIMIT 100&epoch=ms
gives me {“results”:[{“statement_id”:0}]}
while http://####/api/datasources/proxy/1/query?q=SHOW DATABASES
shows {“results”:[{“statement_id”:0,“series”:[{“name”:“databases”,“columns”:[“name”],“values”:[[“initial”]]}]}]}
