Buenos días tengo hecho esta consulta mysql con tablas en GLPI.
SELECT
MONTH(date) AS month,
SUM(CASE WHEN YEAR(date) = 2018 THEN 1 ELSE 0 END) AS "2018",
SUM(CASE WHEN YEAR(date) = 2019 THEN 1 ELSE 0 END) AS "2019",
SUM(CASE WHEN YEAR(date) = 2020 THEN 1 ELSE 0 END) AS "2020",
SUM(CASE WHEN YEAR(date) = 2021 THEN 1 ELSE 0 END) AS "2021",
SUM(CASE WHEN YEAR(date) = 2022 THEN 1 ELSE 0 END) AS "2022",
SUM(CASE WHEN YEAR(date) = 2023 THEN 1 ELSE 0 END) AS "2023",
SUM(CASE WHEN YEAR(date) = 2024 THEN 1 ELSE 0 END) AS "2024"
FROM
glpi_tickets
GROUP BY month
ORDER BY month;
Sin embargo al visualizar en el panel o en una lista de reproducción se ve de la siguiente forma:
En que me estoy equivocando?? gracias por su ayuda.
bien venidos @sebastiannav
En este foro utilizamos el inglés como medio de comunicación.
The data returned by your query has only 1s and 0s
Hello, thank you for your help, in mysql I could not add the [ ], however it remained like this.
SELECT
FROM
glpi_tickets
GROUP BY month (date)
ORDER BY month (date);
Now on the visualization it looks like this…
What is that [ ], not sure I understand
I don’t know how to solve it :c
disregard that, it was me testing your scenario on my sql server. but still not sure I understand your problem. I also do notice your data ranges are 1969
