Grafana 9.3.6, docker
My grafana has grafana-oncall plugin installed
And a few other plugins
Very often the grafana-oncall team upgrades its plugin, while the backend remains the old version
Because of this, the plugin often starts to work incorrectly.
Is it possible to somehow disable the automatic update of one grafana-oncall plugin?
and so that the settings of other plugins do not change?
bump! anyone found some solution?
i managed to fix it, removing directory grafana_storage/plugins/grafana-oncall-ap on the docker server, removing docker instance of grafana (not grafana oncall!) and creating it again via docker-compose.
