Grafana panel embedding in website card at Home Assistant does not work
Hi Guys,
I installed the Grafana Addon in Home Assistant and created a panel (influxDB on different Raspberry Pi, but it works). Now I tried to embed the panel into a website card in my dashboard, but the connection failed.
I already edit the grafana.ini to allow embedding and enabled auth.anonymous. What can I do more?
Best regards, Juergen
Hi. Have you read thru this?
Yes, I did and I was able to embed dashboards on my other Raspberry Pi, but within Home Assistant OS something ist different.
Is there such a thing as home assistant OS?
Or is it installed on another OS. Also what kind of web server is it running on or is it just a client app?
Hi there,
yes it is a complete OS.
The only thing I recognized when watching Tutorial on youtube, there generated URL had used the port 8123. Exchange of ports in the URL does not worked.
It seems that there is no access.
Has been solved by changing http://localhost:3000 to http://homeassistant.local:8123
