Grafana v8.3.3 -
I want to make an alert list dashboard to display the alerts in the fire state, and add a text box after each alert, so that the alert handler, alert processing progress and other information can be entered in the panel -
I don’t now -
What happened?
No function or plugin found for text input -
Hello and welcome to the forum, @lynbit
You might have to design your own panel plugin for this. Although, I do believe that the alerting teams are working on something like this. This type of question gets asked periodically in the forum. Sorry I don’t have a better answer…
