Hi
I’m fairly new to openshift and Grafana, and i really need help with this.
In my openshift cluster i have an Jaeger operator and a Grafana operator. Im then trying to add the Jaeger as a datasource to grafana.
In the docs: Jaeger | Grafana Labs
Is only showing how to connect if you have a user for the Jaeger and then provide the credentials of that user when creating the datasource, but in my case i can’t do that.
I’m trying to connect it with tls certificate. I am using a certificate i know works because that certificate works with Opentelemetry Collector.
I’m getting the error: “Unable to load TLS certificate”
if i disable the oauth-proxy it works. It is the configuration of theTLS that im getting wrong.
The Jaeger operator is the redhat version: https://github.com/jaegertracing/jaeger-operator
Here is the yaml of my datasource:
spec:
datasources:
- access: proxy
isDefault: true
jsonData:
timeInterval: 5s
tlsAuthWithCACert: true
tlsSkipVerify: false
secureJsonData:
tlsCACert: >-
-----BEGIN CERTIFICATE-----
the certificate
-----END CERTIFICATE-----
type: jaeger
url: 'https://jaeger-query.foo.svc.cluster.local:16686'
