Start Grafana after installation
sudo /bin/systemctl start grafana-server
What happened?
$ sudo /bin/systemctl status grafana-server
× grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
Active: failed (Result: exit-code) since Tue 2024-06-11 12:26:55 CEST; 235ms ago
Duration: 1ms
Docs: http://docs.grafana.org
Process: 15490 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${PLUGINS_DIR} cfg:default.paths.provision>
Main PID: 15490 (code=exited, status=127)
CPU: 1ms
Jun 11 12:26:55 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Jun 11 12:26:55 Automation systemd[1]: Stopped grafana-server.service - Grafana instance.
Jun 11 12:26:55 Automation systemd[1]: grafana-server.service: Start request repeated too quickly.
Jun 11 12:26:55 Automation systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Jun 11 12:26:55 Automation systemd[1]: Failed to start grafana-server.service - Grafana instance.
The folder /var/log/grafana is empty. No log file inside.
The file /etc/grafana/grafana.ini has no Logging [log] section. A added ;level = info but the folder /var/log/grafana is still empty.
Jun 11 14:50:08 Automation systemd[1]: Started grafana-server.service - Grafana instance.
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Main process exited, code=exited, status=127/n/a
Jun 11 14:50:08 Automation grafana-server[27519]: /usr/sbin/grafana-server: error while loading shared libraries: libpthread.so.0: ELF load command address/offset not page-aligned
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 1.
Jun 11 14:50:08 Automation systemd[1]: Stopped grafana-server.service - Grafana instance.
Jun 11 14:50:08 Automation grafana-server[27521]: /usr/sbin/grafana-server: error while loading shared libraries: libpthread.so.0: ELF load command address/offset not page-aligned
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 2.
Jun 11 14:50:08 Automation grafana-server[27523]: /usr/sbin/grafana-server: error while loading shared libraries: libpthread.so.0: ELF load command address/offset not page-aligned
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 3.
Jun 11 14:50:08 Automation grafana-server[27524]: /usr/sbin/grafana-server: error while loading shared libraries: libpthread.so.0: ELF load command address/offset not page-aligned
Jun 11 14:50:08 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 4.
Jun 11 14:50:08 Automation grafana-server[27525]: /usr/sbin/grafana-server: error while loading shared libraries: libpthread.so.0: ELF load command address/offset not page-aligned
Jun 11 14:50:09 Automation systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Jun 11 14:50:09 Automation systemd[1]: Stopped grafana-server.service - Grafana instance.
Jun 11 14:50:09 Automation systemd[1]: grafana-server.service: Start request repeated too quickly.
Jun 11 14:50:09 Automation systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Jun 11 14:50:09 Automation systemd[1]: Failed to start grafana-server.service - Grafana instance.
Unfortunately, I’m not a professional. What i have to do?
Add kernel=kernel8.img to file /boot/firmware/config.txt? But I didn’t find any “kernel8.img” in folder /boot/firmware.
