Grafana new alerting: no PagerDuty custom details?
    Grafana v8.3.0 (914fcedb7) on docker
    Sending alerts to PagerDuty with labels, so they can be handled appropriately at PagerDuty’s side
    Switched to new Grafana alerting on that Grafana instance, then tested an alert using PagerDuty API v2 as the contact point.
  • What happened?
All labels and tags of the alert just appear in a details.firing field, but not as separate key-value pairs in the payload. This is the JSON that PagerDuty received:
  "client": "Grafana",
  "client_url": "https://grafana.example.com/",
  "contexts": [
      "href": "https://grafana.example.com/",
      "text": "External URL",
      "type": "link"
  "description": "[FIRING:1]  (alert name)",
  "event_type": "trigger",
  "incident_key": "480b3d163bb8995e036cf2a22e7ac3b9295...",
  "service_key": "36b0c8beeb4647...",
  "details": {
    "firing": "
Value: [ var='B' labels={environment=prod} value=6 ], [ var='C' labels={environment=prod} value=1 ]
Labels:
 - alertname = my alert name
 - env = prod
 - rule_uid = 0g96-O2..
 - environment = prod
Annotations:
 - custom_details.environment = prod
 - description = my alert description
Source: https://grafana.example.com/alerting/0g96-.../edit
Silence: https://grafana.example.com/alerting/silence/new?...
Dashboard: https://grafana.example.com/d/I0hydA...
Panel: https://grafana.example.com/d/I0hyd...?viewPanel=6
    "num_firing": "1",
    "num_resolved": "0",
    "resolved": ""
My labels or tags should appear in the JSON as separate fields. For example:
"details": {
    "environment": "prod",
I’ve looked at the code for the new PagerDuty integration: grafana/pagerduty.go at main · grafana/grafana · GitHub
I don’t see any logic that can set custom fields.
Don’t know what to paste here that could be relevant
No errors.
No
have you had any luck getting this to work? we have the same issue trying to understand how to map the value of “firing” into JSON object
Hey @tehgoti, did you find a solution for your issue? If yes, can you please share it as I need to implement the same.
Thanks
