hi,
i try to test worldmap with this value
CREATE TABLE `worldmap_latlng` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`lat` FLOAT NOT NULL,
`lng` FLOAT NOT NULL,
`name` VARCHAR(20) NOT NULL,
`value` FLOAT NOT NULL,
`timestamp` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=7 DEFAULT CHARSET=latin1;
INSERT INTO `testdb`.`worldmap_latlng`
(`lat`,
`lng`,
`name`,
`value`,
`timestamp`)
VALUES
(50.72213159,
12.45680043,
'RZ5',
1.0,
now());
Worldmap Panel → Metrics:
SELECT
UNIX_TIMESTAMP(`timestamp`) as time_sec,
`value` as value,
`lat` as latitude,
`lng` as longitude,
`name` as name
FROM worldmap_latlng
WHERE $__timeFilter(`timestamp`)
ORDER BY `timestamp` ASC
Worldmap Panel → Worldmap:
- Table Query Format = coordinates
and this value
CREATE TABLE test_map (
time int,
geohash char,
host char,
location char,
value int
) ENGINE=InnoDB CHARSET=latin1;
INSERT INTO test_map
(time, geohash, host, location, value)
VALUES
(1490699614650281185, “dr5rsgyct32n”, “Luv-Inspiron”, “Bangalore”, 19);
SELECT
time as time,
geohash as geohash,
value as value
FROM test_map
ORDER BY time
but i have not value, can you help me please
