My cluster log and system log are collected and displayed by grafana gui. However, the system log of the other virtual machine is not collected. Can you give me information on how I can do it?
Promtail.yml
server:
http_listen_port: 9080
grpc_listen_port: 0
clients:
- url: http://loki-gateway:3100/loki/api/v1/push
tenant_id: 1
positions:
#filename: /tmp/positions.yaml
filename: /run/promtail/positions.yaml
target_config:
sync_period: 10s
scrape_configs:
job_name: kubernetes-pods
pipeline_stages:
- cri: {}
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
action: replace
target_label: __tmp_controller_name
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_name
- __tmp_controller_name
- __meta_kubernetes_pod_name
regex: ^;([^;]+)(;.)?$
action: replace
target_label: app
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_instance
- __meta_kubernetes_pod_label_instance
action: replace
target_label: instance
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_component
- __meta_kubernetes_pod_label_component
action: replace
target_label: component
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
replacement: $1
separator: /
source_labels:
- namespace
- app
target_label: job
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
replacement: /var/log/pods/$1/.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: path
- action: replace
regex: true/(.)
replacement: /var/log/pods/$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
- __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
target_label: path
- action: drop
regex: ^$
source_labels:
- service- job_name: syslog syslog: listen_address: 0.0.0.0:1514 labels: job: syslog relabel_configs: - source_labels: [__syslog_message_hostname] target_label: host - source_labels: [__syslog_message_hostname] target_label: hostname - source_labels: [__syslog_message_severity] target_label: level - source_labels: [__syslog_message_app_name] target_label: application - source_labels: [__syslog_message_facility] target_label: facility - source_labels: [__syslog_connection_hostname] target_label: connection_hostname -
job_name: varlogs_gz
decompression:
enabled: true
initial_delay: 10s
format: gz
static_configs:-
targets:
- localhost
labels:
job: node/varlogs_gz
path: /var/log/**.gz
node_name: ‘onap-grafana-loki’
- localhost
job_name: syslog1
syslog:
listen_address: 10.252.252.78:1514
listen_protocol: tcp
idle_timeout: 60s
label_structured_data: yes
labels:
job: node/syslog1
relabel_configs:- source_labels: [‘__syslog_message_hostname’]
target_label: ‘localhost’
job_name: syslog2
syslog:
listen_address: 192.168.141.195:1514
idle_timeout: 60s
labels:
job: node/syslog2
extraVolumes:
- name: node-logs
hostPath:
path: /var/log
extraVolumeMounts:
- name: node-logs
mountPath: /var/log
readOnly: true
Set fsGroup to allow syslog file reading
podSecurityContext:
fsGroup: 4
Allow environment variables usage
extraArgs:
- -config.expand-env=true
Scrape config to read syslog file from node
ls -1 /var/log/{,/}{[._]log,{mail,news}.{err,info,warn}}
var/log all files => path: /var/log/{,*/}
config:
snippets:
extraScrapeConfigs: |
# Add an additional scrape config for syslog
- job_name: node-all
static_configs:
- targets:
- localhost
labels:
job: node/node-all
path: /var/log/syslog
- job_name: 10.252.252.78
static_configs:
- targets:
- localhost
labels:
job: node/onap_ping_int
__path__: /var/log/syslog
node_name: 'onap-ping'
- job_name: 192.168.141.195
static_configs:
- targets:
- localhost
labels:
job: node/onap_ping
