Promtail syslog receiver , no data in Loki
Hello All,
I started to validate Grafana stack as our security log inspection , i am using docker compose env, we have started Loki & Promtail and Grafana, i configured promtail
scrape job to listen for syslog receiver , also listen on docker compose , both shows they are listen to syslog port.
The issue is that on grafana there is no syslog job nor logs from syslog source.
Below i will share both my docker-compose and promtail config , i probably missed something
Please advice
Thank you
docker compose config
version: "3.8"
networks:
  loki:
volumes:
  prometheus:
  grafana:
  alertmanager-data:
services:
  # Since the Loki containers are running as user 10001 and the mounted data volume is owned by root,
  # Loki would not have permissions to create the directories.
  # Therefore the init container changes permissions of the mounted directory.
  init:
    image: grafana/loki:latest
    user: root
    entrypoint:
      - "chown"
      - "10001:10001"
      - "/loki"
    volumes:
      - ./loki:/loki
    networks:
      - loki
  grafana:
    image: grafana/grafana:latest
    ports:
      - "3000:3000"
    environment:
      GF_AUTH_ANONYMOUS_ENABLED: "true"
      GF_AUTH_DISABLE_LOGIN_FORM: "true"
      GF_AUTH_ANONYMOUS_ORG_ROLE: "Admin"
    volumes:
      - ./config/datasources.yaml:/etc/grafana/provisioning/datasources/datasources.yml
      - grafana:/var/lib/grafana
    networks:
      - loki
  prometheus:
    image: prom/prometheus:latest
    ports:
      - 9090:9090
    volumes:
      - ./config/prometheus.yaml:/etc/prometheus/prometheus.yml
      - prometheus:/prometheus
    command:
        '--log.level=debug',
        '--config.file=/etc/prometheus/prometheus.yml',
        '--query.lookback-delta=30s'
    networks:
      - loki
  # for testing purposes only, disable in production
  log-generator:
    image: mingrammer/flog
    command:
      - --loop
      - --format=json
      - --number=10 # number of log lines to generate per second
      - --delay=100ms # delay between log lines
      - --output=/var/log/generated-logs.txt
      - --overwrite
      - --type=log
    volumes:
      - ./loki/:/var/log/
  promtail:
    image: grafana/promtail:latest
    volumes:
      - ./loki/:/var/log/
      - ./config:/etc/promtail/
    ports:
      - "9080:9080"
      - "1518:1514/udp"
    command: -config.file=/etc/promtail/promtail.yaml
    networks:
      - loki
  minio:
    image: minio/minio
    entrypoint:
      - sh
      - -euc
        mkdir -p /data/loki-data && \
        mkdir -p /data/loki-ruler &&
        minio server /data
    environment:
      - MINIO_ACCESS_KEY=loki
      - MINIO_SECRET_KEY=supersecret
      - MINIO_PROMETHEUS_AUTH_TYPE=public
      - MINIO_UPDATE=off
    ports:
      - "9002:9000"
    volumes:
      - ./.data/minio:/data
    networks:
      - loki
  loki-gateway:
    image: nginx:latest
    volumes:
      - ./config/nginx.conf:/etc/nginx/nginx.conf
    ports:
      - "8080:80"
      - "3100"
    networks:
      - loki
  loki-frontend:
    volumes:
      - ./config:/etc/loki/
    ports:
      - "3100"
    command: "-config.file=/etc/loki/loki.yaml -target=query-frontend -frontend.downstream-url=http://loki-read:3100"
    networks:
      - loki
    deploy:
      mode: replicated
      replicas: 2
  loki-read:
    volumes:
    ports:
      - "3100"
      - "7946"
      # uncomment to use interactive debugging
      # - "40000-40002:40000" # # makes the replicas available on ports 40000, 40001, 40002
      #cap_add:
      #  - SYS_PTRACE
      #security_opt:
      #  - apparmor=unconfined
    command: "-config.file=/etc/loki/loki.yaml -target=read"
    networks:
      - loki
    restart: always
    deploy:
      mode: replicated
      replicas: 3
    # only needed for interactive debugging with dlv
  loki-write:
    volumes:
    ports:
      - "3100"
      - "7946"
      # - "50000-50002:40000" # makes the replicas available on ports 50000, 50001, 50002
      # cap_add:
      #   - SYS_PTRACE
      # security_opt:
    command: "-config.file=/etc/loki/loki.yaml -target=write"
    networks:
      - loki
    restart: always
    deploy:
      mode: replicated
      replicas: 3
  # alertmanager to enable receiving alerts
  alertmanager:
    image: prom/alertmanager:latest
    restart: unless-stopped
    ports:
      - "9093:9093"
    volumes:
      - "./config:/config"
      - alertmanager-data:/data
    command: --config.file=/config/alertmanager.yml --log.level=debug
    networks:
      - loki
promtail config
server:
    http_listen_port: 9080
    grpc_listen_port: 0
    log_level: "info"
positions:
    filename: /tmp/positions.yaml
clients:
    - url: http://loki-gateway:80/loki/api/v1/push
      tenant_id: docker
scrape_configs:
  - job_name: generated-logs
    static_configs:
      - targets:
          - localhost
        labels:
          job: generated-logs
          __path__: /var/log/generated-logs.txt
    pipeline_stages:
      - json:
          expressions:
            http_method: 'method'
            http_status: "status"
      - labels:
          http_method:
          http_status:
  - job_name: syslog
    syslog:
      listen_address: 0.0.0.0:1514
      listen_protocol: udp
      idle_timeout: 60s
      label_structured_data: yes
      labels:
        job: "syslog"
    relabel_configs:
      - source_labels: ['__syslog_message_hostname']
        target_label: 'host'
