I use the docker image grafana/promtail:2.9.2 to deploy my promtail. The varlog jobs are working well.
I use this configuration to have a syslog receiver:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://loki:3100/loki/api/v1/push
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/*log
- job_name: syslog-receiver
syslog:
listen_address: 0.0.0.0:40514
idle_timeout: 12h
use_incoming_timestamp: true
labels:
job: syslog-receiver
relabel_configs:
- source_labels: ['__syslog_message_hostname']
target_label: host
- source_labels: ['__syslog_message_severity']
target_label: level
- source_labels: ['__syslog_message_facility']
target_label: syslog_facility
- source_labels: ['__syslog_message_app_name']
target_label: syslog_identifier
I can see varlogs log entries, working well.
I use the following Python app to test syslogs:
import logging
import logging.handlers
my_logger = logging.getLogger('MyLogger')
my_logger.setLevel(logging.DEBUG)
handler = logging.handlers.SysLogHandler(address = ('v145',40514))
my_logger.addHandler(handler)
my_logger.debug('this is debug')
my_logger.critical('this is critical')
It sends logs to my promtail container. No error. I checked docker logs, no error.
However, this query does not return any logs:
{job="syslog-receiver"} |= ``
How can I diagnose this issue?
