Promtail silently drops incoming syslog messages without any errors
I have the server with stack loki+promtail+syslog-ng run on the docker compose stack with config:
promtail-config
server:
http_listen_port: 9080
grpc_listen_port: 9095
positions:
filename: /tmp/positions.yaml
filename: /etc/promtail/promtail-positions.yaml
clients:
scrape_configs:
  • job_name: nginx-log-collector
    syslog:
    listen_address: 0.0.0.0:601
    label_structured_data: yes
    max_message_length: 65536
    relabel_configs:
    • source_labels: [‘__syslog_message_hostname’]
      target_label: ‘server’
      pipeline_stages:
    • json:
      expressions:
      request_type: request_type
      nginx_service: service
      vhost: server_name
      code: status
      request_time: request_time
      timestamp: time_iso8601
    • timestamp:
      source: timestamp
      format: RFC3339
    • labels:
      request_type:
      nginx_service:
      vhost:
      code:
    • metrics:
      requests_total:
      type: Counter
      description: HTTP requests count
      prefix: http_
      config:
      match_all: true
      action: inc
      request_duration_seconds:
      type: Histogram
      description: HTTP request duration seconds
      prefix: http_
      source: request_time
      config:
      buckets: [0.1,0.2,0.5,0.7,1,2,10,30]
    • match:
      selector: ‘{server=~“.+”} |= “[error]”’
      stages:
      - regex:
      expression: ‘.*request: "(?P<request_type>[A-Z]+) /.*upstream: "\w+://(?P<upstream_addr>\d+.\d+.\d+.\d+:\d+).host: “(?P[a-zA-z.-]+)”.’
      - labels:
      vhost:
      request_type:
      upstream_addr:
syslog-ng-config
@version: 4.7
@include “scl.conf”
options {
create-dirs(yes);
log_fifo_size(1000000);
keep-hostname(yes);
source s_network {
network(ip(“0.0.0.0”) transport(“udp”) port(514));
destination d_loki {
syslog(“promtail” transport(“tcp”) port(601));
log {
source(s_network);
destination(d_loki);
Syslog-ng monitoring reports that outgoing packets to promtail are getting lost.
Messages are not lost at night, i.e. their loss is a consequence of some limits, but which ones?
How do I understand why the messages are lost? What can be configured in the promtail configuration?
