Grafana Loki Helm Installation, Pending Pods with: 0/2 nodes are available: 1 Too many pods, 1 node(s) had untolerated taint
I have the following Helm values for my Loki deployment.
I am running in AWS EKS and have two nodes, an untainted node and a noExecute taint that I intend for my production apps node.
My helm loki installation keeps trying to schedule -write and -read pods into my untolerated node.
yaml
serviceAccount:
  create: true
  imagePullSecrets: []
  annotations:
    eks.amazonaws.com/role-arn: arn:aws:iam::1234567:role/AmazonEKS_EBS_CSI_DriverRole
  automountServiceAccountToken: true
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  storage_config:
    aws:
      region: eu-west-1
      bucketnames: testing.api.logs.chunks
      s3forcepathstyle: false
  pattern_ingester:
    enabled: true
  limits_config:
    allow_structured_metadata: true
    volume_enabled: true
    retention_period: 672h
  querier:
    max_concurrent: 4
  storage:
    type: s3
    bucketNames:
      chunks: testing.api.logs.chunks
      ruler: testing.api.logs.ruler
      admin: testing.api.logs.admin
    s3:
      endpoint: null
      region: eu-west-1
      secretAccessKey: null
      accessKeyId: null
      s3ForcePathStyle: false
      insecure: false
deploymentMode: SimpleScalable
backend:
  replicas: 1
read:
  replicas: 1
write:
  replicas: 1
minio:
  enabled: false
nodeSelector:
  nodeGroup: testing-node-group-t3-large
tolerations:
  - key: "dedicated"
    operator: "Equal"
    value: "production"
    effect: "NoExecute"
I ran the following command:
helm install --values .\values.yml loki grafana/loki -n loki
I also tried:
helm install loki grafana/loki-simple-scalable --set read.replicas=2 --set write.replicas=2 --set loki.auth_enabled=false --values .\values.yml -n loki
However, I constantly see the following warning in my pods:
bash
kubectl describe pod/loki-backend-0 -n loki
sql
Warning FailedScheduling 4m18s (x2 over 9m25s) default-scheduler
taint {dedicated: production}. preemption: 0/2 nodes are available: 1
No preemption victims found for incoming pod, 1 Preemption is not
helpful for scheduling
I added a taint to one of my nodes to allow scheduling only for production apps. My production app has the following toleration:
yaml
tolerations:
  - key: "dedicated"
    operator: "Equal"
    value: "production"
    effect: "NoExecute"
I’ve tried adding the same toleration to my Loki values (see the bottom of the values), but it’s not working. Preferably, I would like the Loki pods to schedule on the non-production node, but at this stage, I just need them to run.
Can someone help me with the following?
How can I add the toleration to my Loki deployment?
How can I ensure Loki pods only schedule on non-tainted nodes?
One node has taint and the second one reached pod limit and cannot start more pods. This is not a problem with your Loki config, but with your EKS. You don’t have resources for more pods. Ask your EKS admin for more resources, so you can run more pods.
