I’ve implemented Loki (v3.1.1) using the SimpleScalable deployment mode via Helm. Here’s a snippet of my custom values.yaml file:
loki:
auth_enabled: false
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
ingester:
chunk_encoding: snappy
tracing:
enabled: true
querier:
# Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
max_concurrent: 4
storage:
bucketNames:
chunks: loki-bucket-xxxxx
ruler: loki-bucket-xxxxx
admin: loki-bucket-xxxxx
s3:
# s3: null
endpoint: https://s3.amazonaws.com
region: us-east-1
secretAccessKey: eZIBinNroYAXnE9nxm93x1NXXXXXXX
accessKeyId: AKIAYYYXXXXXXXXX
# s3ForcePathStyle: true
compactor:
# working_directory: /data/retention
working_directory: /var/loki/compactor
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
delete_request_store: s3
#gateway:
# ingress:
# enabled: true
# hosts:
# - host: FIXME
# paths:
# - path: /
# pathType: Prefix
deploymentMode: SimpleScalable
backend:
replicas: 1
read:
replicas: 1
write:
replicas: 2 # minimum 2 replicas required
# affinity: {}
# place the pods on the same node
affinity:
podAntiAffinity: null
podAffinity:
preferredDuringSchedulingIgnoredDuringExecution:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: write
topologyKey: kubernetes.io/hostname
# Enable minio for storage
# minio:
# enabled: true
# Zero out replica counts of other deployment modes
singleBinary:
replicas: 0
ingester:
replicas: 0
querier:
replicas: 0
queryFrontend:
replicas: 0
queryScheduler:
replicas: 0
distributor:
replicas: 0
compactor:
replicas: 0
indexGateway:
replicas: 0
bloomCompactor:
replicas: 0
bloomGateway:
replicas: 0
chunksCache:
allocatedMemory: 2048
I have few questions:
Persistent Volumes: The deployment created three PVCs:
data-loki-backend-0,data-loki-write-0, anddata-loki-write-1. What exactly is stored in these volumes, and is persistence absolutely required for Loki to function properly? If it is required, how do I configure proper retention policies for these volumes? -
S3 Bucket Content: I’ve configured AWS S3 as the object store, and now I see files such as
loki_cluster_seed.json, afake/directory, and anindex/directory in my S3 bucket. Could someone explain what these files represent? How do they correspond to the configured buckets (admin, chunks, ruler)? -
Retention Configuration: I’ve found it somewhat confusing to configure retention. The documentation seems to mix up Loki’s
config.yamland Helm’svalues.yaml. I attempted to enable the compactor and set the working directory to/var/loki/compactor(the default/data/retentionwas not working). How do I verify that the compactor is working correctly? Are there any clear guidelines for configuring retention when using Helm?
Any guidance or insights would be greatly appreciated!
