Grafana is taking too much time to communicate with prometheus
Hi All,
I am using grafana with Prometheus, i am facing one issue that is grafana is taking too much time to update any metrics.
Example - If any of my instance is down then grafana show after 5 minutes that instance is down same in start condition. can i decrease this time that it will check after 2 minutes to promethues. In prometheus i can see that instance is in stopped state but grafana taking 5 minutes to update single states.
Have you tried to change or adjust the scrape interval on the data sourcce settings or refresh on load ?
Do you have other data sources ? Do you need to update your grafana ? Any settings on your promethius ?
You can also adjust the dashboard refresh interval ?
Scrape interval This will be used as a lower limit for the Prometheus step query parameter. Default value is 15s.
