Grafana is not gathering only outbound usage on the port-channel of cisco ASR1001-X
    Grafana v6.3.2 (4832460)
    Grafana is gathering the information cisco ASR router 1001-X
    but only it is not able to get the information outbound traffic of the interface port-channel.
    Another physical Gi0/0/0 interfaces and Tunnel10 interfaces are okay.
    I have compared the configuration with another router about SNMP.
    because another router is getting the usage on the interface.
    I didn’t find the SNMP configuration missing when I compare it.
  • What happened?
    only port-channel interfaces issue of one router ASR1001-X
    but another same router cisco ASR1001-x is the same hardware.
    I expect gathering the interface usage about outbound traffic of the port-channel on the Cisco ASR1001-X
    I don’t know how I get the configuration from grafana
    but I give the information snmp config on the both router.
    I don’t see an alert relying on the issue.
Graph not get the information out usage on the A router Version 15.5(3)S6
snmp-server community cxxxxxxx RO xx
snmp-server location rancid test
snmp ifmib ifindex persist
Graph get the information out usage on the B router Version 15.6(1)S
    I didn’t change it. it happened and started a very long time ago.
Regards,
Paul Lee
