Grafana is 1 hour ahead
I use Grafana v9.3.2 on a Windows 2016 Server. The server shows correct time in taskbar (timezone Europe/Berlin). A mysql server is running there as well.
If I run following query on the mysql server, it shows correct time:
Grafana1_TimeAhead1
Grafana is set to:
Grafana1_TimeAhead0
If I run the same query in grafana it shows:
Grafana1_TimeAhead2
It is one hour ahead - why please?
What timezone are you in? utc+1?
Yes -Germany is UTC + 1
Because grafana works with UTC, it expects/assumes all datetime columns are utc
@yosiasz: Thanks, does that mean I have to change my SQL query to subtract 1 hour from the result? Or is there any setting in Grafana to compensate that?
Look for functions that convert your datetime column to utc on the fly,dynamically such as following
SELECT Read_date AT TIME ZONE 'UTC'
