Centos 8 -
I’m configuring grafana so that it can go inside another application, I have done it with iframe -
What happened?
Gives content security policy (CSP) error -
It stays with the screen loaded and at the end it shows this, and I have configured it with an embedded iframe.
#</iframe src=“http://192.168.1.129” width=“1540” height=“910”>
which in turn goes to the reverse proxy
create new
ProxyRequests On ProxyPreserveHost On Require all granted # backend server and forwarded path ProxyPass / http://127.0.0.1:3000/ ProxyPassReverse / http:/127.0.0.1:3000/But at the end there is a parameter that he doesn’t like and won’t let him continue, what mistake am I making? Best regards
