Grafana helm chart fails to provision dashboards
    Kubernetes (via k3s) version v1.31.6+k3s1
    Grafana helm chart version 8.12.1 (which deploys appver 11.6.0)
    I am trying to deploy stateless grafana with pre-provisioned dashboards from grafana
    Using a custom values file from the grafana helm charts. Here’s my section on provisioning:
      dashboards:
        default:
          node-dashboard:
            #url: 'https://grafana.com./api/dashboards/1860/revisions/37/download'
            gnetId: 1860
            revision: 37
            datasource: Prometheus
      dashboardProviders:
        dashboardproviders.yaml:
          apiVersion: 1
          providers:
          - name: 'default'
            orgId: 1
            folder: ''
            type: file
            disableDeletion: false
            editable: true
            options:
              path: /var/lib/grafana/dashboards/default
  • What happened?
    I see the following code from the download-dashboards sidecar container sidecar, but I do not see the dashboard in the grafana dashboards page. When I shell into the container running grafana, the file /var/lib/grafana/dashboards/default exists but is blank.
+ set -euf        + mkdir -p /var/lib/grafana/dashboards/default
+ curl -skf --connect-timeout 60 --max-time 60 -H 'Accept: application/json' -H 'Content-Type: application/json;charset=UTF-8' https://grafana.com/api/dashboards/1860/revisions/37/download
+ sed '/-- .* --/! s/"datasource":.*,/"datasource": "Prometheus",/g'
stream closed EOF for grafana/grafana-7b8d758c49-m9wh7 (download-dashboards)
    I expected the dashboards are loaded when I open the page in my grafana instance.
    See above.
    Repeating error below:
    logger=provisioning.dashboard type=file name=default t=2025-04-22T20:44:36.591412407Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
    I used the documentation on the grafana helm charts repo.
Hi @jski185, my names Shawn and I met you today at KubeCON! Since i’m running this locally on a Macbook I used k3d so I could run it using docker instead of k3s like you have but I was successfully able to import the “Node Exporter Full” dashboard with the following values.yaml
dashboards:
  default:
    node-dashboard:
      url: 'https://grafana.com/api/dashboards/1860/revisions/37/download'
      gnetId: 1860
      revision: 37
dashboardProviders:
    apiVersion: 1
    providers:
    - name: 'default'
      orgId: 1
      folder: ''
      type: file
      editable: true
      options:
All I needed to do was
$ helm install my-grafana grafana/grafana --version 8.12.1 -f values.yaml
then port forward the grafana svc
$ kubectl port-forward svc/my-grafana 3000:80
Once that got up and running I navigated to dashboards and see the following.
Hey Shawn, I just copied it into my chart values.yaml and it’s still not wanting to work. I will try and swing by your booth if you’ll still be there tomorrow? I will bring my laptop so I can show you my setup. Cheers!
Here are those logs we were talking about.
From the download-dashboards sidecar:
+ set -euf
stream closed EOF for grafana/grafana-6cbb46cf65-s49cq (download-dashboards)
For the grafana pod after startup:
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:09:50.24021762Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:00.241296784Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:10.24039441Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:20.24061105Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:30.240681199Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:40.24057808Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:10:50.240744992Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:11:00.241045073Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=infra.usagestats t=2025-11-14T03:11:03.96475089Z level=info msg="Usage stats are ready to report"
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:11:10.241013982Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
logger=provisioning.dashboard type=file name=default t=2025-11-14T03:11:20.240368093Z level=error msg="failed to load dashboard from " file=/var/lib/grafana/dashboards/default/node-dashboard.json error=EOF
Inside the grafana pod, the file referenced above is (as you can tell from the error) a 0-byte empty file.
From the grafana cm (with some data redacted):
Namespace:    grafana
Labels:       app.kubernetes.io/instance=grafana
              app.kubernetes.io/name=grafana
              app.kubernetes.io/version=12.1.0
              helm.sh/chart=grafana-9.3.5
Annotations:  argocd.argoproj.io/tracking-id: grafana:/ConfigMap:grafana/grafana
Data
apiVersion: 1
providers:
- disableDeletion: false
  editable: true
  folder: ""
  options:
  orgId: 1
  type: file
datasources.yaml:
apiVersion: 1
datasources:
- access: proxy
  isDefault: true
  type: prometheus
  url: http://prometheus-server.prometheus.svc.cluster.local
- access: proxy
  jsonData:
    httpHeaderName1: X-Scope-OrgID
    tlsSkipVerify: true
  secureJsonData:
    httpHeaderValue1: empty
  type: loki
  url: http://loki-gateway.loki.svc.cluster.local
download_dashboards.sh:
#!/usr/bin/env sh
set -euf
curl -skf \
--connect-timeout 60 \
--max-time 60 \
-H "Accept: application/json" \
-H "Content-Type: application/json;charset=UTF-8" \
  "https://grafana.com/api/dashboards/1860/revisions/37/download" \
  | sed '/-- .* --/! s/"datasource":.*,/"datasource": "Prometheus",/g' \
> "/var/lib/grafana/dashboards/default/node-dashboard.json"
grafana.ini:
[analytics]
check_for_updates = true
[auth]
disable_login_form = true
oauth_auto_login = false
[auth.anonymous]
enabled = false
[auth.generic_oauth]
{redacted}
[grafana_net]
url = https://grafana.net
[log]
mode = console
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[security]
disable_initial_admin_creation = true
[server]
{redacted}
[users]
{redacted}
Happy to keep digging into this!
