v8.3.3 -
Hello, im trying to setup grafana in HA mode running two separate installations (via helm) inside two separate k8s cluster, both connected to same db(postgres), services exposed are being load balanced by external nginx. I have several alerts and alerting channels defined and when i started grafana on second cluster ive got duplicating alerts and increased twice load on datasources. -
What happened?
second grafana duplicated load -
I want to achieve somewhat active/passive configuration if one cluster is down switchover to secondary -
Set up Grafana for high availability | Grafana documentation
