we want to use Grafana Faro for Real User Monitoring. We have the app.environment variable in the initializer but the logs in loki do not have an environment label.
It is part of the “message” or not indexed fields.
Is there an option to define the labels manually? I saw you can define custom labels but is it possible to extract ones from the log?
