Grafana failing to properly parse OAuth Client secrets provided through standard Kubernetes Secret-to-environment variable mapping
    • Grafana version: 12.0.2
    • Operating System: Alpine Linux v3.21 (3.21.3)
    Trying to authenticate with SSO
    • provided Oauth Client secret through standard Kubernetes Secret-to-environment variable mappings.
  • What happened?
    • It’s adding new line characters in to the client secret. Therefore authentication fails.
    • Not add new line characters. Grafana should successfully read and parse the OAuth client secret from the environment variable and complete authentication.
  • logger=authn.service t=2026-01-16T17:31:33.954671787Z level=error msg="Failed to authenticate request" client=auth.client.generic_oauth error="[auth.oauth.token.exchange] failed to exchange code to token: oauth2: \"invalid_client\" \"The client secret supplied for a confidential client is invalid.\"
    N/A
    Full details:
    Grafana appears to fail to properly parse OAuth client secrets when they are provided through standard Kubernetes Secret-to-environment variable mappings.
    Steps to Reproduce:
    1. Create a Kubernetes Secret containing OAuth client credentials
    2. Mount the secret as environment variables using standard K8s envFrom or env with secretKeyRef
    3. Configure Grafana to use these environment variables for OAuth authentication
    4. Attempt to authenticate via OAuth
    **Expected Behavior:**
  • Grafana should successfully read and parse the OAuth client secret from the environment variable and complete authentication.
  • We even tried entering the secret manually in the Grafana UI. That did not work either.
  • We had to hardcode the SSO client secret in Grafana ENVs and commit our code to repository
