Grafana error connecting to Zabbix Triggers
Hello good afternoon.
“Zabbix Triggers” is a communication with zabbix is local and is working normally, only this item occurs.
I already updated my version from 5.1 to 5.2, did not solve.
I changed browser, cleaned history, cache, according to some suggestions in github, but to no avail.
It follows the information of my environment.
Grafana Version: Update: 5.2.3 (commit: cf4c090)
Zabbix Version: 3.2.11
Error below:
Plugin Error
Fetch error: 404 Not Found Instantiating http://192.168.1.50:3000/public/tether-drop Loading http://192.168.1.50:3000/public/plugins/alexanderzobnin-zabbix-app/panel-triggers/ack-tooltip.directive.js Loading plugins/alexanderzobnin-zabbix-app/panel-triggers/module
I did a new install on another server, solved the problem me, temporarily. But I have curiosity in knowing how to solve this, I believe that uploading a new server is not the correct solution for the problem…
