Hi Team,
I have a requirement to customize the grafana UI which has been used as an image pulled from docker hub and ran as an container in openshift. I need to make modification in the color of the Direct Link.
to something like
To make the direct link more prominent I need to make certain changes in css file.
When we use grafana as a single instance i.e., by installing a zipped file and installing. We have this location to change the css–> /grafana-4.4.1/public/css
But when we run as a docker image in an container, I am unable to find such the above mentioned path. Please help!
