I am using Grafana 9.0.5 docker container. I have mounted the default.ini file using ./usr/share/grafana/conf/defaults.ini:/usr/share/grafana/conf/defaults.ini
and it’s working fine properly. I am able to make a change in defaults.ini and it reflecting in Grafana.
Now, I want to change the UI of the Grafana login page using this blog Grafana 103: Customizing Login Screen for Grafana ! Playing with white- labels and many more .. | by Mohit Shrestha | Medium and to make the change I need the files inside the public folder which reside in /usr/share/grafana
When I am trying to mount /usr/share/grafana/:/usr/share/grafana
and by mounting this folder I can make changes in defaults.ini as well. But as soon as I mount this folder it starts giving errors.
/run.sh: line 80: exec: grafana-server: not found
I tried mounting both locations that are default.ini and /usr/share/grafana/
but still, it gives the same error.
This is my docker-compose file.
version: "3"
services:
grafana:
image: grafana/grafana:9.0.4
container_name: grafana
restart: always
ports:
- 3000:3000
networks:
- analytics
volumes:
- grafana-storage:/var/lib/grafana
- ./usr/share/grafana/conf/defaults.ini:/usr/share/grafana/conf/defaults.ini
environment:
- GF_SECURITY_ADMIN_USER=username
- GF_SECURITY_ADMIN_PASSWORD=password
influxdb:
image: quay.io/influxdb/influxdb:v2.0.4
container_name: influxdb
restart: always
ports:
- 8086:8086
networks:
- analytics
volumes:
- /mnt/db/:/mnt/db/
- /mnt/influx/:/mnt/influx/
- ./etc/influxdb/:/etc/influxdb/
- ./etc/influxdb/:/root/.influxdbv2/
# command: sh /etc/influxdb/historical_data_flux_queries/temp.sh
networks:
analytics:
volumes:
grafana-storage:
I am not sure where I am making the mistake. How can I mount the whole folder location so I can make the changes inside the /use/share/grafana
folder
