Grafana Display in Bits/sec
Using Grafana Cloud, with Alloy as collector to scrape SNMP metrics via the built-in SNMP integration, I see my data displayed as Bytes/sec.
Can anyone tell me how to change that? I see lots of guides for prometheus/snmp-exporter however they all tell me to edit files which don’t exist when using alloy.
Thanks!
You can change the unit in grafana:
Hi Raymond,
Thanks for the reply, where do you see that? I see no such option.
Are you using Grafana Cloud, or roll your own?
What dashboard are you using?
Thanks again!
In both local or cloud:
Hi Raymond,
WOW! Thanks a lot!
It makes sense now but I never considered I’d have to change it per panel, I was looking at dashboards and datasources.
Thanks Again!
