AWS Managed Grafana, I see version v9.4.7 on the UI. -
Show a panel with data summed across multiple datasources. -
I will use a datasource variable, which allows multi-select and all-select to select the datasources.
I have a bar chart. -
What happened?
My datasource variable appears as a drop down on the UI. If I select exactly 1 datasource, the data returned is correct. If I select more than 1 datasource, I notice the data returned is for only the first datasource selected as part of the variable. -
I expect to get data from all datasources selected within the datasource drop down. -
Here is my Query
No errors. -
No
