Hello community,
I have a problem with my first dashboards and hope that you can help me here.
The dashboard is still quite simple. I have a few tables and gouges that I retrieve from different OpenSearch indexes.
I have defined a variable for the connection of the indexes.
Currently two DataSources are matching on this variable.
In the selection menu I can select both and I get the correct data back from both. However, as soon as I set All, I only see the data from one DataSource. This is also defined as the default if this is important.
Same problem if I change the variable to Multi and select both sources.
Is this a known problem or do I have a comprehension problem here? I understand that if I select All, all data from all DataSources are displayed at the same time!
Variabe:
Type: Data source
Type: OpenSearch
Filter: ^wz1-.*
Include All option
Sample Query of Table:
_index:wazuh-alerts-* AND data.application:CTINotify
As already mentioned: All data can be retrieved individually, as soon as I have more sources, only the data from one source is displayed.
Grafana v10.4.2 (701c851be7) in Docker
Thank you for your advice!
Best regards,
Bastian
