What Grafana version and what operating system are you using? 8.5.0
I am trying to color my points based on value , if value is 1 → Green, value is 2–> Blue, value is 3 → Red -
How are you trying to achieve it? I have tried, thresholds, I have tried gradients but nothing so far has worked, is this possible with Grafana?
What happened? It colors all my points the same color based on min, max or last tab that I select when I setup thresholds
What did you expect to happen? N/A → trying to understand if this is even possible
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. N/A
Welcome
Check this out, color by overrides
so this is coloring three different series by three colors, however i want to color data in one series only
