Color Bar Chart based on Groups
    Grafana v10.3.1
    I try to have all bars within a group colored by the same color.
    I have tried a singe pgsql query and also merged multiple pgsql queries in table mode.
    I set “Color by field” to the grouped field → didn’t work
    I tried overrides based on clicking on the legend and selecting a color → didn’t work
    I tried multiple color schemes → didn’t work
  • What happened?
    All charts of all groups have the same color. I can change all from green to blue or whatever but I cannot use the color to distinct between different groups and the x-legends to distinct within those groups.
    When using overrides I just see “field_value (not found)” in the override
    I expected that all bars of a each group (same value in the specific field) selected in “color by field” to have the same color.
    No
    No
    I checked multiple posts here in the forum, for example the suggestion to use multiple queries but was not successful with that.
