Grafana dashboard running slow after upgrading to 11.1.4
HI Team I was using grafana 10.2.2 version to display my postgres database data on grafana dashboard it used to work fine in10.2.2 version later I upgraded to 11.1.4 then i’m facing issue on dashboard few queries taking more time than usual but same time when I executed queries on the postgres it’s taking less time to fetch the data so what could be the reason and how can I fix the issue
Probably you should add your case to this github issue:
I believe its still not fix to this day..
@devisyam do you have a fast working dashboard under v12? If so I might upgrade directly to v12.. Otherwise I will stick using the old grafana version that is very much performant.
