Grafana 11.3.2, Opensearch 2.18.0 -
Query data from Opensearch data source to Grafana dashboard -
What happened?
I setup an Opensearch data source, however when I try to build a dashboard, in the query editor an error is displayed TypeError: (0 , on.isAction) is not a function -
The window where you can register the query normally should be visible. -
An unexpected error happened
Details
at Qn (https://grafana-s3.prosvasis.itml.space/public/plugins/grafana-opensearch-datasource/module.js?_cache=2.22.2:26:18835)
at eval (https://grafana-s3.prosvasis.itml.space/public/plugins/grafana-opensearch-datasource/module.js?_cache=2.22.2:89:868)
at l (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:1:172)
at o (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:204:119128)
at g (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:204:119637)
at div
at div
at div
at of (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:25115)
at On (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:185:4277)
at Rf (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:29655)
at vf (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:29785)
at c (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:668:68)
at div
at z (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:4564:820)
at div
at Yf (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:30071)
at y (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:185:1972)
at kf (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:12762)
at ct (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:62:949)
at Wl (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:14510)
at W (https://grafana-s3.prosvasis.itml.space/public/build/3866.59307a0fe632af6e8c63.js:62:4511)
at div
at div
at div
at div
at div
at q (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:120:79486)
at i (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:204:30032)
at oe (https://grafana-s3.prosvasis.itml.space/public/build/2559.8679bf64736b1e79bf27.js:6:57)
at $s (https://grafana-s3.prosvasis.itml.space/public/build/DashboardPage.e2d3ad7d8dcc28c6a4e3.js:333:3917)
at div
at g (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:296:44822)
at div
at https://grafana-s3.prosvasis.itml.space/public/build/DashboardPage.e2d3ad7d8dcc28c6a4e3.js:333:5465
at div
at div
at i (https://grafana-s3.prosvasis.itml.space/public/build/3866.59307a0fe632af6e8c63.js:1:2296)
at div
at i (https://grafana-s3.prosvasis.itml.space/public/build/3866.59307a0fe632af6e8c63.js:1:4281)
at J (https://grafana-s3.prosvasis.itml.space/public/build/3866.59307a0fe632af6e8c63.js:1:9619)
at div
at div
at div
at div
at div
at W (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:600:4400)
at Hs (https://grafana-s3.prosvasis.itml.space/public/build/DashboardPage.e2d3ad7d8dcc28c6a4e3.js:350:1115)
at On (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:181:96397)
at WithTheme(Connect(Hs))
at pt (https://grafana-s3.prosvasis.itml.space/public/build/DashboardPage.e2d3ad7d8dcc28c6a4e3.js:425:473)
at DashboardPage
at Suspense
at Kf (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:4943:331)
at ve (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:216:23557)
at fa (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:207:4727)
at fn (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:207:10217)
at ks (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:216:11746)
at ve (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:216:25752)
at div
at div
at main
at div
at Af (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:4940:2407)
at zt (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:207:9607)
at nu (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:216:12045)
at ve (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:216:19722)
at div
at l (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:224:13290)
at v (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:37:13858)
at d (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:629:177403)
at d (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:823:19916)
at y (https://grafana-s3.prosvasis.itml.space/public/build/958.b63f864e3aa7eee86718.js:181:94091)
at zf (https://grafana-s3.prosvasis.itml.space/public/build/4019.8e650672867c3e4c40ad.js:4954:122)
