I’m using terraform to create resources for my Grafana Cloud instance but I’m getting an error that I can’t dig deeper into.
I’m trying to configure the AWS Observability Provider by creating a token that has the necessary permissions and instantiating a provider with the necessary configuration. When it comes time to create the AWS account resource by submitting a POST to the cloud API it fails and I can’t understand why. I am able to create the AWS account manually which confirms that the role and everything else I’m doing is valid.
Here is my configuration
provider "grafana" {
alias = "cloud"
// terraform cloud access policy
cloud_access_policy_token = var.cloud_access_policy_token
data "grafana_cloud_stack" "main" {
provider = grafana.cloud
slug = "xxx"
data "grafana_cloud_organization" "current" {
slug = "xxx"
resource "grafana_cloud_access_policy" "aws" {
region = data.grafana_cloud_stack.main.region_slug
name = "aws-cloudwatch-policy"
display_name = "AWS Cloudwatch Policy"
scopes = [
"integration-management:read",
"integration-management:write",
"stacks:read"
realm {
type = "org"
identifier = data.grafana_cloud_organization.current.id
resource "grafana_cloud_access_policy_token" "aws" {
access_policy_id = grafana_cloud_access_policy.aws.policy_id
name = "aws-cloudwatch-policy-token"
display_name = "AWS Cloudwatch Policy Token"
alias = "aws"
cloud_provider_url = format("https://cloud-provider-api-%s.grafana.net", data.grafana_cloud_stack.main.cluster_slug)
cloud_provider_access_token = grafana_cloud_access_policy_token.aws.token
resource "grafana_cloud_provider_aws_account" "main" {
provider = grafana.aws
stack_id = data.grafana_cloud_stack.main.id
role_arn = "xxx"
regions = [
"us-west-1",
"us-west-2"
resource "grafana_cloud_provider_aws_cloudwatch_scrape_job" "main" {
name = "aws-resource-metadata-scraper"
aws_account_resource_id = grafana_cloud_provider_aws_account.main.resource_id
service {
name = "AWS/CertificateManager"
metric {
name = "DaysToExpiry"
statistics = ["Average"]
scrape_interval_seconds = 86400
And here is the subsequent error I get during resource creation
grafana_cloud_provider_aws_account.main: Creating...
grafana_cloud_provider_aws_account.main: Still creating... [10s elapsed]
│ Error: Failed to create AWS Account
│ with grafana_cloud_provider_aws_account.main,
│ on main.tf line 582, in resource "grafana_cloud_provider_aws_account" "main":
│ 582: resource "grafana_cloud_provider_aws_account" "main" {
│ failed to create AWS account: failed to do request: Post "https://cloud-provider-api-prod-us-central-3.grafana.net/api/v2/stacks/xxx/aws/accounts": POST
│ https://cloud-provider-api-prod-us-central-3.grafana.net/api/v2/stacks/xxx/aws/accounts giving up after 4 attempt(s)
