Thanks for getting back to me.
The results of the test are copied below (sans the hostname and IP address of my host).
In the meantime, I fired up Grafana in Docker on my laptop and discovered that it was trying to access .../api/v1/query attached to the URL I provide it, which taught me that it expects a Prometheus endpoint, not a “raw metrics” endpoint which returns things like:
# TYPE node_scrape_collector_success gauge
# TYPE node_nf_conntrack_entries gauge
node_nf_conntrack_entries 654
# TYPE node_nf_conntrack_entries_limit gauge
node_nf_conntrack_entries_limit 64512
node_scrape_collector_duration_seconds{collector="conntrack"} 0.0018692016601562
node_scrape_collector_success{collector="conntrack"} 1
# TYPE node_boot_time_seconds gauge
node_boot_time_seconds 1743309252
I have since configured the Docker-based Prometheus to scrape the metrics from the OpenWRT, then configured the Docker-based Grafana to use it for dashboards.
I’m working on repeating this using Grafana Cloud now.
My question now is: Can Cloud Grafana scrape the raw metrics directly? Or do I have to have Prometheus or something equivalent between the raw metrics and Cloud Grafana?
The motivation is to reduce the number of moving parts required for monitoring in my home network to the minimum.
Here are the test results:
Service detected: HTTP
Testing protocols via sockets except NPN+ALPN
SSLv2 not offered (OK)
SSLv3 not offered (OK)
TLS 1 not offered
TLS 1.1 not offered
TLS 1.2 offered (OK)
TLS 1.3 offered (OK): final
NPN/SPDY not offered
ALPN/HTTP2 h2, http/1.1 (offered)
Testing cipher categories
NULL ciphers (no encryption) not offered (OK)
Anonymous NULL Ciphers (no authentication) not offered (OK)
Export ciphers (w/o ADH+NULL) not offered (OK)
LOW: 64 Bit + DES, RC[2,4], MD5 (w/o export) not offered (OK)
Triple DES Ciphers / IDEA not offered
Obsoleted CBC ciphers (AES, ARIA etc.) offered
Strong encryption (AEAD ciphers) with no FS offered (OK)
Forward Secrecy strong encryption (AEAD ciphers) offered (OK)
Testing server's cipher preferences
Hexcode Cipher Suite Name (OpenSSL) KeyExch. Encryption Bits Cipher Suite Name (IANA/RFC)
SSLv2
SSLv3
TLSv1
TLSv1.1
TLSv1.2 (no server order, thus listed by strength)
xc030 ECDHE-RSA-AES256-GCM-SHA384 ECDH 521 AESGCM 256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
xc028 ECDHE-RSA-AES256-SHA384 ECDH 521 AES 256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
xc014 ECDHE-RSA-AES256-SHA ECDH 521 AES 256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
xcca8 ECDHE-RSA-CHACHA20-POLY1305 ECDH 521 ChaCha20 256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
x9d AES256-GCM-SHA384 RSA AESGCM 256 TLS_RSA_WITH_AES_256_GCM_SHA384
xc0a1 AES256-CCM8 RSA AESCCM8 256 TLS_RSA_WITH_AES_256_CCM_8
xc09d AES256-CCM RSA AESCCM 256 TLS_RSA_WITH_AES_256_CCM
x3d AES256-SHA256 RSA AES 256 TLS_RSA_WITH_AES_256_CBC_SHA256
x35 AES256-SHA RSA AES 256 TLS_RSA_WITH_AES_256_CBC_SHA
xc02f ECDHE-RSA-AES128-GCM-SHA256 ECDH 521 AESGCM 128 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
xc027 ECDHE-RSA-AES128-SHA256 ECDH 521 AES 128 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
xc013 ECDHE-RSA-AES128-SHA ECDH 521 AES 128 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
xc0a0 AES128-CCM8 RSA AESCCM8 128 TLS_RSA_WITH_AES_128_CCM_8
xc09c AES128-CCM RSA AESCCM 128 TLS_RSA_WITH_AES_128_CCM
x9c AES128-GCM-SHA256 RSA AESGCM 128 TLS_RSA_WITH_AES_128_GCM_SHA256
x3c AES128-SHA256 RSA AES 128 TLS_RSA_WITH_AES_128_CBC_SHA256
x2f AES128-SHA RSA AES 128 TLS_RSA_WITH_AES_128_CBC_SHA
TLSv1.3 (no server order, thus listed by strength)
x1302 TLS_AES_256_GCM_SHA384 ECDH 253 AESGCM 256 TLS_AES_256_GCM_SHA384
x1303 TLS_CHACHA20_POLY1305_SHA256 ECDH 253 ChaCha20 256 TLS_CHACHA20_POLY1305_SHA256
x1301 TLS_AES_128_GCM_SHA256 ECDH 253 AESGCM 128 TLS_AES_128_GCM_SHA256
Has server cipher order? no (NOT ok)
(limited sense as client will pick)
Testing robust forward secrecy (FS) -- omitting Null Authentication/Encryption, 3DES, RC4
FS is offered (OK) TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-AES256-SHA384 ECDHE-RSA-AES256-SHA
ECDHE-RSA-CHACHA20-POLY1305 TLS_AES_128_GCM_SHA256 ECDHE-RSA-AES128-GCM-SHA256 ECDHE-RSA-AES128-SHA256 ECDHE-RSA-AES128-SHA
Elliptic curves offered: prime256v1 secp384r1 secp521r1 X25519 X448
Finite field group: ffdhe2048 ffdhe3072 ffdhe4096 ffdhe6144 ffdhe8192
TLS 1.2 sig_algs offered: RSA-PSS-RSAE+SHA512 RSA-PSS-RSAE+SHA384 RSA-PSS-RSAE+SHA256 RSA+SHA512 RSA+SHA384 RSA+SHA256 RSA+SHA224
TLS 1.3 sig_algs offered: RSA-PSS-RSAE+SHA512 RSA-PSS-RSAE+SHA384 RSA-PSS-RSAE+SHA256
Testing server defaults (Server Hello)
TLS extensions (standard) "server name/#0" "max fragment length/#1" "supported_groups/#10" "EC point formats/#11" "application layer protocol negotiation/#16"
"encrypt-then-mac/#22" "extended master secret/#23" "session ticket/#35" "supported versions/#43" "key share/#51"
"renegotiation info/#65281"
Session Ticket RFC 5077 hint 3840 seconds, session tickets keys seems to be rotated < daily
SSL Session ID support yes
Session Resumption Tickets: yes, ID: yes
TLS clock skew Random values, no fingerprinting possible
Certificate Compression none
Client Authentication none
Signature Algorithm SHA256 with RSA
Server key size RSA 2048 bits (exponent is 65537)
Server key usage Digital Signature, Key Encipherment
Server extended key usage TLS Web Server Authentication, TLS Web Client Authentication
Serial 0542262ADE4F2FDCE099BABAE5D9D47CEA31 (OK: length 18)
Fingerprints SHA1 3CDA985FE44F5D76EE9F92C649ECCBEDAF32F448
SHA256 A7AD9DDAA4988C69741CC0917F02636C2D511DA926807BA3FE3FE129521F0882
Common Name (CN) domain.com
subjectAltName (SAN) *.domain.com domain.com
Trust (hostname) Ok via SAN wildcard (same w/o SNI)
wildcard certificate could be problematic, see other hosts at
https://search.censys.io/search?resource=hosts&virtual_hosts=INCLUDE&q=A7AD9DDAA4988C69741CC0917F02636C2D511DA926807BA3FE3FE129521F0882
Chain of trust NOT ok (chain incomplete)
EV cert (experimental) no
Certificate Validity (UTC) 88 >= 30 days (2025-04-08 07:54 --> 2025-07-07 07:54)
ETS/"eTLS", visibility info not present
Certificate Revocation List http://r10.c.lencr.org/50.crl
OCSP URI http://r10.o.lencr.org
OCSP stapling not offered
OCSP must staple extension --
DNS CAA RR (experimental) not offered
Certificate Transparency yes (certificate extension)
Certificates provided 1
Issuer R10 (Let's Encrypt from US)
Intermediate Bad OCSP (exp.) Ok
Testing HTTP header response @ "/metrics"
HTTP Status Code 401 Unauthorized WWW-Authenticate: Basic realm="Metrics"
HTTP clock skew -8 sec from localtime
Strict Transport Security not offered
Public Key Pinning --
Server banner nginx/1.25.0
Application banner --
Cookie(s) (none issued at "/metrics") -- HTTP status 401 signals you maybe missed the web application
Security headers --
Reverse Proxy banner --
Testing vulnerabilities
Heartbleed (CVE-2014-0160) not vulnerable (OK), no heartbeat extension
CCS (CVE-2014-0224) not vulnerable (OK)
Ticketbleed (CVE-2016-9244), experiment. not vulnerable (OK)
ROBOT not vulnerable (OK)
Secure Renegotiation (RFC 5746) supported (OK)
Secure Client-Initiated Renegotiation not vulnerable (OK)
CRIME, TLS (CVE-2012-4929) not vulnerable (OK)
BREACH (CVE-2013-3587) no gzip/deflate/compress/br HTTP compression (OK) - only supplied "/metrics" tested
POODLE, SSL (CVE-2014-3566) not vulnerable (OK), no SSLv3 support
TLS_FALLBACK_SCSV (RFC 7507) No fallback possible (OK), no protocol below TLS 1.2 offered
SWEET32 (CVE-2016-2183, CVE-2016-6329) not vulnerable (OK)
FREAK (CVE-2015-0204) not vulnerable (OK)
DROWN (CVE-2016-0800, CVE-2016-0703) not vulnerable on this host and port (OK)
make sure you don't use this certificate elsewhere with SSLv2 enabled services, see
LOGJAM (CVE-2015-4000), experimental not vulnerable (OK): no DH EXPORT ciphers, no DH key detected with <= TLS 1.2
BEAST (CVE-2011-3389) not vulnerable (OK), no SSL3 or TLS1
LUCKY13 (CVE-2013-0169), experimental potentially VULNERABLE, uses cipher block chaining (CBC) ciphers with TLS. Check patches
Winshock (CVE-2014-6321), experimental not vulnerable (OK)
RC4 (CVE-2013-2566, CVE-2015-2808) no RC4 ciphers detected (OK)
Running client simulations (HTTP) via sockets
Browser Protocol Cipher Suite Name (OpenSSL) Forward Secrecy
Android 6.0 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 7.0 (native) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 8.1 (native) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 253 bit ECDH (X25519)
Android 9.0 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Android 10.0 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Android 11 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Android 12 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Chrome 79 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Chrome 101 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Firefox 66 (Win 8.1/10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Firefox 100 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
IE 6 XP No connection
IE 8 Win 7 No connection
IE 8 XP No connection
IE 11 Win 7 TLSv1.2 ECDHE-RSA-AES256-SHA384 256 bit ECDH (P-256)
IE 11 Win 8.1 TLSv1.2 ECDHE-RSA-AES256-SHA384 256 bit ECDH (P-256)
IE 11 Win Phone 8.1 TLSv1.2 AES128-SHA256 No FS
IE 11 Win 10 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 256 bit ECDH (P-256)
Edge 15 Win 10 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 253 bit ECDH (X25519)
Edge 101 Win 10 21H2 TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Safari 12.1 (iOS 12.2) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Safari 13.0 (macOS 10.14.6) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Safari 15.4 (macOS 12.3.1) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Java 7u25 No connection
Java 8u161 TLSv1.2 ECDHE-RSA-AES256-SHA384 256 bit ECDH (P-256)
Java 11.0.2 (OpenJDK) TLSv1.3 TLS_AES_128_GCM_SHA256 256 bit ECDH (P-256)
Java 17.0.3 (OpenJDK) TLSv1.3 TLS_AES_256_GCM_SHA384 253 bit ECDH (X25519)
go 1.17.8 TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
LibreSSL 2.8.3 (Apple) TLSv1.2 ECDHE-RSA-CHACHA20-POLY1305 253 bit ECDH (X25519)
OpenSSL 1.0.2e TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 256 bit ECDH (P-256)
OpenSSL 1.1.0l (Debian) TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 253 bit ECDH (X25519)
OpenSSL 1.1.1d (Debian) TLSv1.3 TLS_AES_256_GCM_SHA384 253 bit ECDH (X25519)
OpenSSL 3.0.3 (git) TLSv1.3 TLS_AES_256_GCM_SHA384 253 bit ECDH (X25519)
OpenSSL 3.5.0 (git) TLSv1.3 TLS_AES_256_GCM_SHA384 253 bit ECDH (X25519)
Apple Mail (16.0) TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 256 bit ECDH (P-256)
Thunderbird (91.9) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Rating (experimental)
Rating specs (not complete) SSL Labs's 'SSL Server Rating Guide' (version 2009q from 2020-01-30)
Specification documentation https://github.com/ssllabs/research/wiki/SSL-Server-Rating-Guide
Protocol Support (weighted) 0 (0)
Key Exchange (weighted) 0 (0)
Cipher Strength (weighted) 0 (0)
Final Score 0
Overall Grade T
Grade cap reasons Grade capped to T. Issues with the chain of trust (chain incomplete)
Grade capped to A. HSTS is not offered
