Grafana Cloud does not find PostgresSQL
Hi.
I set up postgres on localhost:5432 using Grafana locally (community.grafana.com). It works everything and I have my local dashboard.
Now I would like to use grafana cloud and share my dashboard with everybody but Grafana does not find any table inside my postgres database. The set-up is the same as the local one.
What am I missing? Thanks.
Welcome to the community, did you specify your public IP address ? Also did you authorize (firewall) traffic to your database ?
Hope it helps.
Good Luck
