Grafana Cloud + Postgres
First time using Grafana Cloud.
I have a postgres DB on my laptop. I want to connect Grafana Cloud to this DB. The connection fails.
In the Grafana cloud data source config I’m using localhost:5432, etc.
Im not clear about how the grafana cloud instance is suppose to talk to my local DB. Does the DB need to be publicly reachable for grafana cloud to reach it?
@tjw74 Yes, it does. You will need a static IP address and open firewall ports for Grafana Cloud to reach your local database.
I would suggest using a dedicated Postgres instance from any Cloud provider, or https://supabase.com is a friendly alternative instead.
Makes sense, thank you for the recommendations.
Is there a VPN option or ssh tunnel ability?
