Grafana can't display new group of zabbix
Hello everyone.
I created dashboard and it worked well.
When I added new groups in zabbix I didn’t recognize it in grafana. Grafana can’t see new groups.
I rebooted granafa but this action didn’t help me.
How it fix?
Found answer myself:
Problem was - user permissions in Zabbix.
I checked them and new group became visible
You helped me very much
@alex35 – Hi I am facing same issue that new group in not visible in grafana. Can you let me know user permissions you checked in zabbix to resolve the issue?
Hello @kshitijarora67
Check the user’s permissions on the Zabbix side if they have hostgroup access, the user is the one configured in the Gratana datasource connection.
Another test that can be done is to try with the zabbix Admin user.
It is important to remember that only host groups that have a host with collection will appear.
