Grafana Barchart vis with datalinks
I am using grafana 8.3, i have been using the barchart visualisation. Data links in bar chart are not working. i have set data links at root as well as the override level for the field. but the hyperlinks are not getting activated. is this feature available for barchart.? The same is available in bargauge though.
Seems like this feature is fixed and working in Grafana 8.4 onwards with bar chart.
