Grafana AzureAD Authentication behind NGINX rproxy, on AKS
Hey everyone!
We’ve recently moved from an on-prem K8s cluster to an AKS cluster and are using ArgoCD Autopilot to deploy everything as per the GitOps principles.
We’ve successfully deployed Grafana behind NGINX, but we encountered an issue when attempting to add Azure AD authentication into the mix; the issue in our case lies with Grafana. Essentially, we cannot inject values into ‘grafana.ini’ as per the suggested helm-chart approach.
Here are the approaches we’ve tried to take with this issue:
  1. Injecting values individually:
apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
  namespace: argocd
  annotations:
    argocd.argoproj.io/sync-wave: "55"
  finalizers:
    - resources-finalizer.argocd.argoproj.io
spec:
  project: keeper-dev
  source:
    repoURL: https://grafana.github.io/helm-charts
    targetRevision: 6.51.2
    chart: grafana
    helm:
      parameters:
      - name: "'grafana.ini'.server.root_url"
        value: "https://grafana.tmlab.local"
      - name: "'grafana.ini'.'auth.azuerad'.name"
        value: "AZ"
      - name: "envFromSecret"
        value: "grafana-azure-ad"
  destination:
    server: https://kubernetes.default.svc
    namespace: grafana
  syncPolicy:
    automated:
      selfHeal: true
      prune: true
    syncOptions:
    - CreateNamespace=true
The referred secrets were actually passed through to the pod's environment:
  GF_AUTH_AZUREAD_CLIENT_ID: "<CLIENTID>"
  GF_AUTH_AZUREAD_CLIENT_SECRET: "<CLIENTSECRET>"
2) Injecting these parameters as variables, utilizing the helm chart's "envfromEnv" value:
  GF_SERVER_ROOT_URL: <VALUE>
  GF_AUTH_DISABLE_LOGIN: <VALUE>
  GF_AUTH_AUTO_LOGIN: <VALUE>
  GF_AUTH_AZURE_AUTH_ENABLED: <VALUE>
  GF_AUTH_AZUREAD_NAME: <VALUE>
  GF_AUTH_AZUREAD_ENABLED: <VALUE>
  GF_AUTH_AZUREAD_AUTO_LOGIN: <VALUE>
  GF_AUTH_AZUREAD_CLIENT_ID: <VALUE>
  GF_AUTH_AZUREAD_CLIENT_SECRET: <VALUE>
  GF_AUTH_AZUREAD_AUTH_URL: <VALUE>
  GF_AUTH_AZUREAD_TOKEN_URL: <VALUE>
  GF_AUTH_AZUREAD_ALLOWED_DOMAINS: <VALUE>
  GF_AUTH_AZUREAD_ALLOW_GRAFANA_ADMIN: <VALUE>
  GF_AUTH_AZUREAD_ALLOW_SIGN_UP: <VALUE>
The most progress I got was to receive the error 'err-too many redirects' upon passing these values as envfromSecret, as shown in the above code snippet.
3) Parsing all values as is written in the 'grafana.ini' file:
kind: Application
metadata:
  namespace: argocd
  annotations:
  finalizers:
spec:
  project: keeper-dev
  source:
    chart: grafana
    helm:
      parameters:
      - name: "grafana.ini.auth.azuread"
        value: -|
          [auth.azuread]
            name = Azure AD
            enabled = true
            allow_sign_up = true
            auto_login = false
            scopes = openid email profile
            auth_url = https://login.microsoftonline.com/7d524a33-f832-4631-9e10-bd43d817e0a5/oauth2/v2.0/authorize
            token_url = https://login.microsoftonline.com/7d524a33-f832-4631-9e10-bd43d817e0a5/oauth2/v2.0/token
            allowed_domains =
            allowed_groups =
            role_attribute_strict = false
            allow_assign_grafana_admin = true
            skip_org_role_sync = false
  destination:
    namespace: grafana
  syncPolicy:
    automated:
      selfHeal: true
      prune: true
    syncOptions:
Provided secrets:
Any feedback would be highly appreciated.
