Grafana Audit Log Filtering
I use Grafana enterprise version and have enabled Audit logging.
I want to only record Folder Movements/actions. I do not want to record all changes in the platform.
Edit:
I added these flags in [auditing] as well as [security] (found online to try to do this) also but no change.
log_datasource_query_request_body = false
log_datasource_query_response_body = false
Do you have a valid license for your Grafana Enterprise?
yes its valid.
There is no filtering option for audit logs:
So you need to build infra for that, e. g
send audits logs to otel collector, where you implement filtering and then collector ingest filtered logs into Loki.
But why is the flags not working as intended? even after they are set to false.
and what are these flags supposed to record?
Provide reproducible example pls - e.g. version, what is configured, what is logged, what is expected to be logged, …
Anyway, you have licensed enterprise version, so you have support from vendor directly. Why you don’t contact your Grafana support?
