- Grafana cloud 1.6.0-84214
- grafana-amazonprometheus-datasource (v2.0.0)
Using temp credentials (Grafana Assume Role) for the Amazon Managed Prometheus datasource.
Configure AWS authentication | Grafana documentation -
Currently the Amazon Managed Prometheus data source only has an option for Secret ID and Secret Key based auth. I would like it to work like the CloudWatch data source with awsDatasourcesTempCredentials enabled.
There is no option for that. Your only option is to request that feature from your Grafana support.
