Connecting AWS account with Grafana Cloud CloudWatch datasource
I have a grafana cloud account (Free version), I’m trying to get AWS cloudwatch connected to this grafana account.
I’m trying using the cloudwatch datasource and create an assume role in my AWS account. But I’m getting an error. Below are the details,
Below is my AWS account role policy,
  "Version": "2012-10-17",
  "Id": "groundcover-cloudwatch-integration",
  "Statement": [
      "Sid": "AllowReadingMetricsFromCloudWatch",
      "Effect": "Allow",
      "Action": [
        "cloudwatch:ListMetrics",
        "cloudwatch:GetMetricData",
        "cloudwatch:GetInsightRuleReport",
        "cloudwatch:DescribeAlarmsForMetric",
        "cloudwatch:DescribeAlarms",
        "cloudwatch:DescribeAlarmHistory"
      "Resource": "*"
      "Sid": "AllowReadingLogsFromCloudWatch",
      "Effect": "Allow",
      "Action": [
        "logs:StopQuery",
        "logs:StartQuery",
        "logs:GetQueryResults",
        "logs:GetLogGroupFields",
        "logs:GetLogEvents",
        "logs:DescribeLogGroups"
      "Resource": "*"
      "Sid": "AllowReadingTagsInstancesRegionsFromEC2",
      "Effect": "Allow",
      "Action": [
        "ec2:DescribeTags",
        "ec2:DescribeRegions",
        "ec2:DescribeInstances"
      "Resource": "*"
      "Sid": "AllowReadingResourcesForTags",
      "Effect": "Allow",
      "Action": "tag:GetResources",
      "Resource": "*"
Below is the trust relationship of the role(account ID of grafana hosted account and external ID is given),
    "Statement": [
            "Effect": "Allow",
            "Principal": {
                "AWS": "arn:aws:iam::XXXXXXX:root"
            "Action": "sts:AssumeRole",
            "Condition": {
                "StringEquals": {
                    "sts:ExternalId": "XXXXX"
Then I fills out the cloudwatch datasource as below in grafana(only fills the marked fields),
Also I only have below option in the drop down,
When I save this I will get the below error,
I’m not sure what I’m doing wrong here, I will get the same error even if I give the administrator access to this role.
Your help will be appreciated :folded_hands:
You need a user (access key id/secret), which will be allowed to assume that role in your current setup:
You can also use only the assume role feature (without any user/credentials), but that’s a feature in the private preview in Grafana Cloud (+ it is more complicated from the user perspective):
Thank you for the reply.
So this means currently grafana needs a IAM user created for this? and then the user needs to assume the role we provided?
No, your current Grafana/datasource setup needs an IAM user.
The linked doc is for the case where you don’t need an IAM user.
